Bearing Specialists Association (BSA) and the Power Transmission Distributors Association (PTDA) announce the introduction of seals, linear bearings profile rail, bushings (hub fixing devices), chains and sprockets to the PIE Technology Platform (PIE).
On September 19th, Todd Hamlin, BSA president, and senior vice president of DXP Enterprises, announced the Annual BSA Excellence Awards for outstanding service by bearing distributors and bearing manufacturers to end-users.
life in this application.
When the need arises for linear motion
or positioning, there are many choices.
One can use an Acme screw, ball screw,
rack & pinion, or belts. The cost of a linear motor solution is generally greater than a mechanical linear product, but when one needs highly accurate, repeatable, high-speed motion, then the answer may be a linear motor.
Ernest Head (Arnie), CBS and technical
sales representative at Motion Canada
helped save a lumber industry customer
time and money by adapting a bearing
solution for another client. Here’s how:
