Power Transmission Engineering is the magazine of mechanical components. When you think of gear drives, bearings, motors, couplings, clutches, brakes and similar products, we want you to think of us. But achieving such front-of-mind presence is one of the most difficult goals in publishing...
Hannover Messe 2012 generated enough buzz that the 5,000 exhibitors “will have their work cut out for them,” according to Dr. Wolfram von Fritsch, chairman of the managing board of Deutsche Messe. “Green technologies are a viable business model with the power to drive growth around the world.
