After getting positive feedback on changes made to the show last year, AWEA Wind Power is doubling down and taking their ongoing transformation even further.
Three electric motor repair facilities share best practices for utilizing copper in motor repair, and recommending new
motors to replace older, less-efficient motors
Does the definition of specific sliding mean the same between ISO 21771:2007 and AGMA 917-B97? In ISO, specific sliding is the ratio of the sliding speed to the speed of a transverse profile in the direction of the tangent to the profile. In AGMA, specific sliding is ratio of gear tooth sliding velocity to its rolling velocity.
life in this application.
