Implementing product lifecycle management strategies can be intimidating at first glance, but it's also necessary. Here's why and how you should implement a PLM strategy of your own.
When you work day-in and day-out with components like gears, bearings or electric motors, for example, it's easy to forget that those components are always part of a much bigger system.
life in this application.
