Force Control Industries presents a maintenance-free, no-adjustment crane brake that virtually eliminates crane downtime as well as the need to perform maintenance and adjustment at height. The MagnaShear motor brake employs oil shear technology, providing longer service life in demanding applications like the frequent start/stop cycles seen on cranes, hoists, and winches.
The engineering community is fascinated with big, shiny, yellow machines. Walk into any manufacturing facility around the globe and you’ll find guests huddled around the biggest, loudest, and most intimidating equipment on the shop floor. These large machines must play by the same rules as everybody else—they need to reduce energy consumption, lower plant costs, and increase productivity. Many power transmission component suppliers are tasked with optimizing this equipment.
Robotic applications in manufacturing need precise movement and positioning in manufacturing operations from teach pendant programming through full, automated production with exact sequential motion and timed positioning. Miki Pulley BXR Brakes apply holding torque after the motor joint stops and provides dynamic braking in the event of an emergency such as a power interruption.
Torque transducers, test machinery, industrial robots, food and beverage and chemical applications are just a few of the areas coupling technology is advancing. This short round-up covers some of the latest product and industry news items in the power transmission and motion control market segments.
Torque Transducers and Test Machinery experience extreme demands including high torque loads and high operating speeds which cause stress on connected components. To assure these systems generate accurate test data when experiencing these conditions, system designers specify CD Couplings from Zero-Max.
Siemens Digital has added features and updates for Simcenter SPEED, Simcenter Motorsolve and Simcenter MAGNET 2022.1 to improve accuracy, flexibility and connectivity. This 2022.1 update makes Simcenter SPEED and Simcenter Motorsolve more accurate and better integrated to Simcenter STAR-CCM+.
Preventing unplanned downtime in industrial processes only gets more important during times of high demand. The cost of gearbox, motor and drive shaft replacement often pales in comparison to that of the lost production resulting from mechanical torque overload failures caused by jams, collisions and binding in the driveline. This makes mechanical circuit breaking technology more important than ever since a fast, tool free reset and recovery from torque overload minimizes interruption.
