Q&A: My company manufactures high-speed metal forming machines. We have one application on a feed axis where we are encountering problems with the coupling...
In most cases, industrial power transmission calls for flexible rather than rigid couplings in order to forgive minor shaft misalignment. For that reason, this article will focus solely on the selection of flexible couplings.
The use of motor structures which can concentrate magnetic flux allows ferrite PM motors to achieve performance and power densities that approach those of PM motors using rare earth magnets, but without the cost penalties and supply source concerns of rare earth magnets.
elements on the machine tool.
