SMT's latest webinar "MASTA Support - Tips, Tricks and FAQ" will take place May 4, 2022. The SMT customer support team receive queries covering all areas of MASTA, with industry 'hot topics' inevitably arising. In this webinar, SMT engineers focus on answering some of the queries that frequently make it into their support inbox.
The main function of rolling bearings is to support load and transmit rotational movement with minimum energy loss. In order to achieve this, bearings are manufactured with particularly good quality fatigue resistance materials, proper design and tight manufacturing tolerances. Particular emphasis is put in both the macro, and micro geometry of the working shapes and surfaces of the raceways. Rolling bearings come in many types and sizes as ball and roller bearings for radial and thrust loads.
When comparing bearing suppliers,
engineers are often left with few options
other than to compare dynamic
load ratings and corresponding life
calculations. Of course, we can look at
steel and manufacturing quality; but
if we are comparing sources of similar
quality, those items may not provide
a large contrast. It often surprises
people to learn that bearing capacities
are calculated values, not tested values.
Lately, however, a trend is emerging
for bearing suppliers to increase their
ratings for higher performance bearings
that have premium features such
as higher quality steel and specilaized
heat treatment. Bearing companies are
under intense competitive pressure to
make every feature add to the dynamic
capacity of their bearings because it is very well understood that an increase in capacity adds to the bottom line.
"Well begun is half done," a quote that most reference materials attribute to Aristotle, certainly applies when selecting mechanical power transmission
products. A selection process that is well thought out at the start can ensure that the product selected will be properly sized and appropriate to the application at hand.
Implementing a predictive maintenance
(PM) program can be tough. Despite its proven success, many companies have been operating the same way for over 50 years and don’t know where to start. Understanding where to start and where to focus is critical. The intention of this article is to give insight to start and sustain an effective program using today’s technology and devices.
