February 2, 2023
In this paper, the models for different power loss sources in transmissions from literature are applied and compared, which form the two methods - ISO 14179-2 and the joint model to estimate the power losses in a transmission. A 2-speed transmission in an electric vehicle is used as a case study to compare the two methods and validate them with experimental data.
