Closed-loop control systems can handle a wide range of motions with a wide range of loads if the control system and the mechanics of the system are properly designed for the task. A couple of the more difficult combinations to design for are high inertial mismatches and backlash with hard gearing. The question is not just how to make the system stable but also how to get the desired performance.
AutomationDirect has added more ACCU-Torq motors from Nidec U.S. Motors. The ACCU-Torq motors are high-performance inverter duty motors and are an excellent cost-effective solution for applications that require 100 percent torque down to zero speed. They are available in 230/460 VAC and are now offered in sizes up to 20 hp at 1,800 rpm and from ¼ to 10 hp at 1,200 rpm.
ABB has completed the acquisition of Aurora Motors. The transaction was originally announced on November 4, 2024, and financial terms were not disclosed. Aurora Motors is a $4 million U.S. vertical pump motors provider, with engineering and operations in Shanghai, China, and a corporate office and distribution center in Hayward, California.
From electric motors and linear actuators to robots and gearboxes, the range of equipment and machinery used to create automation in industrial applications is diverse. Each has its own set of sealing requirements and understanding these critical components requires many years of experience. In this article David Kaley, Trelleborg’s global segment manager for industrial automation, shares his insights on sealing needs for electric motors. Standard, elastomer-based radial shaft seals as well as high-performing PTFE-based seals are discussed.
WEG supplied medium voltage synchronous motors to CEDAE at the Lameirão Pumping Station in Rio de Janeiro, Brazil. These motors will play a crucial role by pumping water to a significant part of the city, ensuring reliability and continuity for the state’s population.
ABB is opening its NEMA Motors Division world headquarters in Fort Smith, Arkansas, to the local community on Thursday, October 3, in celebration of Manufacturing Day (MFG Day), officially observed on Friday, October 4. This open house event is intended to educate and inspire students, parents, educators and community leaders about the future of manufacturing careers. ABB plans to engage with attendees through facility tours, demonstrating the industry’s critical role in driving innovation and highlighting diverse, sustainable career paths.
