EDITORS’ NOTE: “The Applications of Bevel Gears” is the excerpted third chapter of Dr. Hermann Stadtfeld’s latest book — Gleason Bevel Gear Technology (The Gleason Works,
Rochester, New York, USA; All rights reserved. 2014; ISBN 978-0-615-96492-8.), which appears here unabridged through the kind graces of Dr. Stadtfeld and Gleason Corp. Future installments will appear exclusively in Power Transmission Engineering
and Gear Technology magazine over the next 12 to
18 months.
A reader asks: I've determined that a stainless steel bearing is the best option for my application. I'm being asked to specify the grade of stainless steel in my product design. I'm not sure which grade to select and specify. Can you help?
We are pleased to present our first annual Engineering Showcase, a celebration of some of the leading products and companies in mechanical power transmission. In the pages that follow, you’ll find examples of engineering excellence and technological know-how in the field of gears, drives, couplings, machine parts and other mechanical components.
The development of a new, gas-carburized gear steel, necessitated by a customer-driven specification, has not only increased the power density in an existing gearbox design, but has done so without requiring any significant change to production processes or heat treatment equipment.
This paper is part 2 of 2 in a series that summarizes the chemical, metallurgical and physical aspects of bearing steels and their effect on rolling bearing life and reliability.
A new solution has been developed around
the use of microprocessor-controlled
prostheses. Just like natural limbs, these
can react automatically, adapting to the
current situation.
