Siemens Digital Industries Software has announced the 2025 release of Solid Edge software, bringing new capabilities to its product development software. The latest release also introduces Solid Edge X software, delivering a cloud-enabled secure Software as a Service (SaaS) environment, enhanced with new AI-enabled tools to help users work smarter.
IIjin Electric's collaboration with Siemens began with the company's efforts to effectively integrate electrical design with mechanical design. “This collaboration went beyond simply changing tools. It represented a major advancement in the company's design approach and methodology.
Solid Edge is a portfolio of affordable, easy-to-use software tools that address all aspects of the product development process. Solid Edge combines the speed and simplicity of direct modeling with the flexibility and control of parametric design – made possible with synchronous technology. The following Q&A discusses Solid Edge 2024 with Dan Staples, vice president, mainstream engineering, Siemens Digital Industries Software.
In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
Siemens Digital Industries Software recently announced that Tianneng Battery Group Co., Ltd. has selected the Siemens Xcelerator portfolio of industry software to help it drive innovation and enable digital manufacturing in new battery production.
Siemens Digital Industries Software and IBM recently announced they are expanding their long-term partnership by collaborating to develop a combined software solution integrating their respective offerings for systems engineering, service lifecycle management and asset management.
Welcome back to Part 2 of our inner ring and creep discussion. We left off with our creep calculation resulting in a 10.5 µm minimum inner ring fit to avoid creep. For the sake of making clean dimensions, let’s call it 10 µm on the lower end and the upper end is simply whatever your manufacturer can hold.
PTE will feature a variety of new component technologies online for bearings, motors, couplings, brakes, gear drives, and motion control systems leading up to Hannover Messe 2023 in Germany. Here is a preview of some bearings suppliers to check out if you're planning on attending the event online or in-person in April.
