Applied Motion Products New PH Series Mini Planetary Gearmotors are used with small step motors in NEMA 8, 11, and 14 frame sizes. The small design of the gearheads allows them to be paired with small motors and doesn't adversely affect the outside dimensions of the combined gearmotor.
In its largest order to date, Danish wind turbine test specialist R&D Test Systems will develop the 30 MW powertrain and gearbox test bench for ZF Wind Power’s future “Test & Prototype Center” at Lommel, Belgium. Capable of simulating the multiplicity of wind loads that a nacelle powertrain might experience in its lifetime, the test rig, to be delivered in 2024, will help improve product reliability and shorten time to market.
Stober Relies on FVA Workbench for Drive Verification
September 30, 2022
Stöber Antriebstechnik GmbH + Co. KG rely on the FVA-Workbench for dimensioning and verification of their drives. The calculation and simulation software allows Stöber engineers to develop their innovative gear unit solutions more quickly and efficiently. The result: higher quality products.
