Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
The development of a new, gas-carburized gear steel, necessitated by a customer-driven specification, has not only increased the power density in an existing gearbox design, but has done so without requiring any significant change to production processes or heat treatment equipment.
All major manufacturers of 3-phase
AC induction motors offer "inverter-duty" or "inverter-ready” models, but while these motors have inverter-rated insulation to protect the windings, the bearings--their most vulnerable parts--are too often ignored.
