The use of motor structures which can concentrate magnetic flux allows ferrite PM motors to achieve performance and power densities that approach those of PM motors using rare earth magnets, but without the cost penalties and supply source concerns of rare earth magnets.
Next time you are strolling across a manufacturing plant, check out the hardware on the ground. Shop floors are nothing but cables plugged into machines, cables plugged into computers, cables plugged into other cables...
elements on the machine tool.
