In the KISSsoft shaft calculation, the proof of fatigue strength can be performed by generating an equivalent stress verification according to the FKM Guideline.
SMT's May workshops aim to give attendees the tips and tricks needed to further improve the fidelity of the MASTA model. In this workshop, SMT engineers will go through some of the tools available including:
Today’s competitive industrial gear marketplace demands products with excellent reliability, high capacity and low noise. Surface-hardened, ground tooth gearing predominates, but the legacy tooth forms handicap further improvements in capacity and noise generation. Vehicle and aircraft equipment use tooth forms not found in the standard tables to achieve better performance — with little or no increase in cost. This paper will propose adopting these high-contact ratio forms to industrial use.
