KISSsoft has announced that NSK has provided their extensive bearing data “catalogue data” for inclusion in KISSsoft software with release 2023. With this, the engineer can execute static rating, basic and modified life rating based on load capacity numbers in line with ISO 281 and ISO 76 along with thermal rating. The bearing database in KISSsoft gives access to up-to-date NSK bearing data in an easy to use yet detailed manner using the shaft-bearing system modeler.
The Neugart Calculation Program (NCP) configuration tool reliably leads to the most cost- and energy-efficient gearbox-motor combination. In the new NCP 4.3 version the performance of the program has been improved further through enhanced multi-core usage of the processor. Above all, effective immediately the proven software will offer many additional features and optimizations - including better comparisons and rack-and-pinion drives.
With the help of KISSsoft, the user can combine the FE method with analytical models when designing a high-performance gear or drivetrain. The stiffness matrix of a gear body can be calculated accurately with KISSsoft using its advanced modeling capabilities for gear bodies. The effect of the gear body stiffness can be integrated in different KISSsoft calculations, like flank line modifications and loaded tooth contact analysis.
GWJ Technology GmbH, a calculation specialist from Braunschweig, Germany, added new functions to the gear modules of its eAssistant web-based calculation software, which has been successful for more than 20 years.
Siemens Digital Industries Software and IBM recently announced they are expanding their long-term partnership by collaborating to develop a combined software solution integrating their respective offerings for systems engineering, service lifecycle management and asset management.
In the KISSsoft shaft calculation, the proof of fatigue strength can be performed by generating an equivalent stress verification according to the FKM Guideline.
Mechanical engineering theory, design and practice come into play for NYCU Vulpes Racing Team
April 6, 2023
The new KISSsoft release 2023 comes with numerous novelties. Among others, Gear Mesh Frequencies (GMF) can now be calculated for cylindrical and bevel gears. GMF results are visualized in two different diagrams, i.e. GMF versus rotational frequency of the reference gear, and GMF versus amplitude.
