Step motors come in many sizes and shapes. But they all share one item in common - each step motor type moves in discrete-degree steps. They react to a series of voltage pulses supplied by their basic controller, known as an "indexer." The step motor was the first to accept digital pulses, then move or rotate a prescribed amount without any feedback device. All step motors are position devices without the need to use any feedback devices. They operate primarily in an open-loop control scheme.
After a brief introduction to the importance of gear pumps in internal combustion engines, as well as in the most diverse hydraulic applications, a calculation method was applied that allows for sizing with considerably higher delivery rates. Upon identifying and analyzing a traditional pump, along with two construction solutions of asymmetric gear pumps, we then compared their related performances.
This paper outlines the design considerations that go into construction of a drive system in order to explain the importance of specific data, why it is required, and where design freedom is necessary. Apart from loads and speeds, interface dimensions and site specific conditions are also needed. Deciding up front which gear rating practice to select can affect the torque capacity of the drive train by ~15%.
Involute splines are commonly used in gearboxes to connect gears and shafts, especially when high torque is transmitted through the coupling. The load is shared among multiple teeth around the coupling circumference, resulting in higher load capacity than a conventional single key. However, the total load is not equally shared among all spline teeth, mainly because of
pitch deviations resulting from the manufacturing process. The load distribution along the spline engagement length is also nonuniform
because of tooth misalignments and shaft torsional effects. This paper presents an investigation of the influence of spur gear loads on the load distribution of spline teeth.
Mounted ball bearings are everywhere in industrial applications. They serve critical roles in keeping a manufacturing operation running smoothly and in ensuring that equipment functions properly and reliably. So why might it be advisable to spend significantly more for a dimensionally
comparable bearing from one supplier versus another?
