New Lubrication System from Oil Rite March 16, 2005 The new Purge X infrared lubrication system from Oil Rite is designed for use in automotive, conveyor, packaging and textile industries. ...Read More
New Encoder from BEI March 16, 2005 The HMT25 multi-turn absolute encoder from BEI has an electronic reset capability. According to the companys press release, the ...Read More
Worlds Smallest Linear Actuator Introduced by Haydon Switch & Instrument March 16, 2005 The Size 8 hybrid external linear actuator was introduced by Haydon Switch & Instrument. The 0.8" size makes this the worlds smalle...Read More
New Furnace from Grieve March 9, 2005 The No. 943 pit furnace from Grieve is an electrically heated, top loading pit furnace capable of 2,000 degrees F and is suitable for hea...Read More
New Linear Motors from Aerotech March 2, 2005 The BLMFS5 Series flat linear motors from Aerotech provide 25% more power in an equivalent envelope than traditional models.This is achie...Read More
New Line of Timing Belts and Pulleys from BRECOflex February 26, 2005 The ARC Power Plus line of timing belts and pulleys from BRECOflex are available as open-ended, spliced and welded endess and truly endle...Read More
Micronors Motorized Potentiometers Include 4-20 mA Control Option February 21, 2005 The MR267 current loop controller (CLC) option remotely controls a motorized potentiometer and/or rotary cam switch via 4-20mA current ...Read More
New Scanner from Induction Tooling February 20, 2005 The Model No. Scan I.T-LRS36 scanner from Induction Tooling was introducted at Gear Expo 2005. According to the companys literat...Read More
New Digital Servo Amplifiers from Aeroech February 20, 2005 The Ndrive MP digital servo amplifier from Aerotech is the ultra-compact, high performance discrete drive option for the Automation 3200 ...Read More
Pacamor Kubar Bearings Enhanced for Dental Handpieces February 20, 2005 Pacamor Kubar Bearings has introduced new product enhancements that extend bearing life in high and low speed dental and surgical handpie...Read More
