New Encoders from Renishaw January 7, 2005 The RELM line of high accuracy encoders from Renishaw combine accuracy to +/1 micron/m and resolution to 23 nm with speeds above 10 m/s ...Read More
New Ball Screws from PIC Design January 6, 2005 A new family of ball screws from PIC Design can handle higher load capacites at faster speeds with improved capacities. According to t...Read More
New DC Gearmotor from Midwest Motion January 6, 2005 A new DC gearmotor, Model No. MMP.TM55-24V.GP52-100.1 can accept any 24 volt source, including battery power. According to the compan...Read More
Harmonic Drive Introduces New Gearheads January 3, 2005 Harmonic Drive Technologies introduced its RGH Series of compact gearheads that offer the accuracy and repeatability typically associated...Read More
New Wheels from Saint-Gobain January 27, 2004 The Univel DC Deep Cut Wheels are superabrasive grinding wheels that are designed for manufacturing and reconditioning tools and inserts ...Read More
New Planetary Roller Screw Assemblies from Nook January 27, 2004 The NRS planetary roller screw assemblies from Nook Industries is designed for the most precise linear motion applications. These roll...Read More
New Hydrodynamic Brake from Voith Turbo January 27, 2004 Voith Turbo has designed a new industrial retarder (hydrodynamic brake) for simulating various load conditions of diesel engines. Four...Read More
New Bore Gauge from Marposs January 19, 2004 The M1Star MBG mechanical bore gauge from Marposs is designed for manual mechanical use in precision checking of I.D., ovality or taper o...Read More
New Gear Catalog from Suhner Manufacturing January 1, 2004 Suhner Manufacturing has released its flexible shaft/bevel gear catalog. According to the companys press release, this new catal...Read More
New Bearing Steels from NSK December 31, 2003 The newest steels, "Z", "EP" and "SHX" from NSK provide spindle bearings with resistance to seizure and minimum levels of heat generation...Read More
