One-Piece Belt Drive Permits Sag-Free Stroke Lengths April 12, 2010 The model AZ1040 drive is the latest extension to the Amacoil-Uhing line of timing belt drives used for smooth linear motion in positio...Read More
High Capacity Torque Limiter Uses Vibration Damping Jaw Type Coupling April 9, 2010 The ST2 series torque limiter from R+W allows for one compact unit to be installed, saving space and cost when into a high horsepower dri...Read More
Cleveland Gear Broadens Product Offerings April 8, 2010 A line of shaft mount reducers and accessories is available now from Cleveland Gear Company, including tapered bushing kits, belt guards,...Read More
Proximity Sensor Measures Without Touching Target April 7, 2010 The KD-2446 high-precision proximity sensor system from Kaman Precision Products offers lead-free RoHS compliance in a compact DIN packa...Read More
Commercial Elevator Double Brake Developed April 6, 2010 In response to new safety measures that require passenger elevators to have double redundant braking systems, Ogura Industrial Corp. has ...Read More
Wire Rope Isolators Designed for Heavy-Duty Military and Industrial Applications April 2, 2010 A series of 70 wire rope isolators from Advanced Antivibration Components (AAC) feature multiaxial shock and vibration protection, corros...Read More
Rotary Encoder Collars Give Shafts Speed Sensing Capability April 2, 2010 Stafford Manufacturing Corp. offers shaft collars that can be customized with steel pick-up targets on the face or outside diameter to al...Read More
100mm AC Electric Motors Offer Power of Larger Motors in Less Volume April 1, 2010 In response to customer demand for more power in smaller spaces, Bison Gear and Engineering introduces the 100mm AC motor line offeri...Read More
Product News April 1, 2010 The complete product news section from the April 2010 issue of Power Transmission Engineering.Read More
Kollmorgen Drive Delivers Scalable Programmability March 31, 2010 The Advanced Kollmorgen Drive (AKD) is Ethernet-based and delivers high performance with flexibility, scalability and power range for mos...Read More
