Maxon Motor Assists Space Probe August 18, 2014 After more than ten years of travel through space, the European space probe Rosetta has reached the comet Chury. Three months from now, f...Read More
Aerotech Introduces Piezo Nanopositioners August 15, 2014 Aerotech’s QNP-L series linear piezo nanopositioning stages give nanometer-level performance in a compact, high-stiffness package. ...Read More
Zero-Max Offers Right Angle Gear Drives August 14, 2014 Lubricated for life with Beacon 325 premium grade grease, Zero-Max Crown drives feature heat treated AGMA Class 10 spiral bevel gears. Th...Read More
Siemens Offers AC Power Modules for G120 Drives August 13, 2014 A new line of PM240-2 power modules is now available from Siemens, extending the use of the popular Sinamics G120 drives family. A signif...Read More
MDA Preview: ZF August 12, 2014 ZF has pooled its comprehensive knowhow for the new hollow shaft drives from the Duoplan model range. Consequently, the ZF-Duoplan 2K 150...Read More
Oriental Introduces Linear Slides and Cylinders August 11, 2014 Oriental Motor USA is proud to introduce its newest and most cost effective linear actuators, the EAS Series motorized linear slides and ...Read More
Altra Couplings Solves Vibration Issues for Large Pumps August 7, 2014 A large raw water pumping station in Malaysia was suffering from severe vibration problems with the drivetrains on a number of large pump...Read More
Taylor Hobson Offers Bearing Measurement Tool August 6, 2014 A precision surface measurement tool featuring an industry-leading high-speed column drive, precision positioning and 4 mm roundness and ...Read More
SKF Optimizes Bolt Mounting August 5, 2014 SKF Spherical Washers optimize bolt mounting of machinery and bolted equipment by integrating unique design features promoting suitable p...Read More
Hedienhain Expands Rotary Encoders August 4, 2014 Heidenhain is expanding its third generation of absolute inductive rotary encoders with the ExI 11xx series, providing a single encoder s...Read More
