Fenner Drives RotoShield GTL Provides Defense Against Torque Overloads December 28, 2015 Fenner Drives recently announced the launch of RotoShield Gearbox Torque Limiters. RotoShield GTL stops damage from costly torque overloa...Read More
Nord Gear Soft Starters Eliminate Mechanical Strain December 24, 2015 Nord Gear offers the SK135E/SK175E soft start drive family. The starters are designed to be used in a distributed control system and ca...Read More
Aerotech Gimbals Offer High Accuracy Positioning December 23, 2015 A series of gear-driven motorized gimbals for high-accuracy elevation-over-azimuth positioning has been introduced by Aerotech. The new A...Read More
Steinmeyer UltraThrust Ball Screws Receive Upgrade December 22, 2015 Steinmeyer, Inc. has updated UltraThrust ball screw series, with diameters from 32 mm to an enormous 160 mm diameter, pitch ranging ...Read More
Ringfeder TSCHAN TNR Couplings Designed for Wide Range of Rigidity December 21, 2015 Unlike commonly used, torsionally elastic shaft couplings, the TSCHAN TNR is adjustable and therefore allows for a ...Read More
Timken Launches 6000 Series Ball Bearings in North America December 18, 2015 Timken recently launched its 6000 series deep groove ball bearing line in North America, which completes the compan...Read More
Leeson Electric Extreme Duck Motor Designed and Pressure Tested for Washdown Applications December 17, 2015 Leeson Electric has launched the next generation Extreme Duck Motor. The new design is built to ensure that liquids don’t penetrate...Read More
Miki Pulley PBZ Variable Torque Brakes Feature Magnetic Particle Brakes December 16, 2015 Miki Pulley has introduced their PBZ Variable Torque Brakes for direct sale to OEMs in North America. Ideal for variable torque tensionin...Read More
Oerlikon Champion Series Drives Present Three Models Designed for Self-Propelled Spray Tractors December 15, 2015 Oerlikon’s Drive Systems Segment, with its brand Oerlikon Fairfield, recently displayed its new Champion Series of drives at Agrite...Read More
Boston Gear Mounted Bearings and Universal Joints Added to Stainless Steel Food Processing Line December 14, 2015 Boston Gear has added new mounted bearing designs and universal joints to its line of stainless steel shaft accessories designed for supe...Read More
