Metallized Carbon Corp. Offers Carbon-Graphite Materials for Aircraft Shaft Seals July 29, 2016 Metallized Carbon Corporation offers a variety of materials for mechanical seals in aircraft shaft applications, including main shaf...Read More
SEPAC Designs Thin Spring-Engaged Brake July 28, 2016 SEPAC designed the Thin Spring-Engaged Brake (TSEB) to provide OEMs with a thin body high-performance/low-cost spring engaged power off b...Read More
Curtiss-Wright Launches High-Pressure Valve Sensor July 27, 2016 Curtiss-Wright’s Industrial division has launched the all-new VPT351 valve-position sensor featuring a measurement range of 0-10 mm...Read More
Cortec EcoShield 386 Water Based Coating Achieves 1,000 Hours of Salt Spray Testing July 26, 2016 Through the Nano VpCI coatings chemistry of Cortec Laboratories, the first water based coating has been created to withstand a minimum 1,...Read More
Fenner Drives Introduces 3V and 5V Wedge Link Belts July 26, 2016 Combining excellent service and long life with exceptional inventory control, the new Wedge Link Belting from Fenner Drives yield major a...Read More
SKF Battery-Driven Grease Gun Offers Unique Lubrication Solutions July 25, 2016 The new SKF Battery-Driven Grease Gun (TLGB 20) introduces an ideal portable tool to maximize the efficiency and accuracy of manual lubri...Read More
AppliMotion Offers Low-Profile DDR Motors July 22, 2016 The Infinity Series enables OEMs to move light payloads in smooth and accurate arc-shaped and full 360-degree rotary motion profiles. Ult...Read More
H2W Technologies Offers Miniature Voice Coil Actuators July 21, 2016 H2W Technologies offers miniature versions of both its moving coil and moving magnet voice coil actuators. Additionally, they offer...Read More
Alliance Sensors S1A and SC-100 Signal Conditioners Reduce Setup and Calibration Time July 20, 2016 Alliance Sensors Group has developed the S1A and SC-100 DIN-rail-mounted, push-button-calibrated LVDT signal conditioners by listening to...Read More
Bison Offers Integral HP Reducers and Gearmotors July 20, 2016 Bison now carries a full line of integral horsepower reducers and gearmotors that range in power from 1 - 5 hp. This new line of products...Read More
