Thomson Expands Electrak Linear Actuator Line January 30, 2018 Thomson Industries, Inc. has extended the capability of its popular Electrak HD electromechanical linear actuator line to loads of up t...Read More
Parker Hannifin Releases ACRView Motion Development Software January 29, 2018 Parker’s Electromechanical and Drives Division North America is pleased to announce the release of ACRView version 6.4.2, which all...Read More
Tolomatic Choke Valve Actuator Improves Managed Pressure Drilling Process January 26, 2018 The new Tolomatic ServoChoke SVC electric choke valve actuator meets requirements for a more flexible and reliable high-speed actuator in...Read More
Dana Offers Axle/Gearbox Combination for Drum Rollers January 25, 2018 Dana Incorporated has announced a new, optimized axle/gearbox combination for small- and medium-sized single drum rollers that enables or...Read More
Bison Gear Launches Web-Based 3D CAD Configurator January 24, 2018 Bison Gear and Engineering has launched an all-new online configurator of digital CAD models for their most popular gearmotors. The confi...Read More
Igus Offers Spherical Balls for Retrofitted Bearing Housings January 23, 2018 Pillow block and flange bearings are commonly used in construction machines and conveyor systems, therefore they are often exposed to dir...Read More
OES Introduces Cross-Roller Linear Stages January 22, 2018 Optimal Engineering Systems, Inc. (OES) offers a high precision series of low cost, low profile motorized single axis positioning stages....Read More
Varvel Offers RS and RT Series Worm Gearboxes January 19, 2018 The Varvel RS and RT series worm gearboxes demonstrate the company’s versatility and innovation for a variety of demanding applicat...Read More
KISSsoft 03/2018 Beta Version is Available for Testing January 18, 2018 The KISSsoft 03/2018 Beta Version has now been released for a test run. The final release will be available from April 23rd, 2018 - just ...Read More
Ruland Mountable Shaft Collars Offer High Holding Power January 17, 2018 Ruland has released a new line of mountable shaft collars with flats and tapped holes or tapped holes only in the outer diameter, allowin...Read More
