Aerotech Offers Integrated Granite Motion Systems July 3, 2018 Machine components such as bearings, encoders, and drive mechanisms are engineered and assembled directly on the granite base and bridge ...Read More
Miki Pulley Magnetic Couplings Transmit Torque with Non-Contact Shaft-to-Shaft Connection July 2, 2018 Miki Pulley’s Magnetic Couplings transmit torque from one shaft to another using a magnetic field rather than a mechanical connecti...Read More
Intellidrives Rotary Servo Table Features Outer Rotor Design June 29, 2018 Intellidrives new direct drive rotary servo table includes an outer rotor design. This allows for increased performance, greater magnetic...Read More
Gearing Solutions Yaw Drives Offer Efficient Power-to-Weight Ratios June 28, 2018 Using unique roller gear technology, Gearing Solutions wind turbine Yaw Drives have an unparalleled power to weight ratio, achieving grea...Read More
Igus Introduces Bearing Drylin W Exchange for Linear System June 27, 2018 Igus has introduced a new bearing, drylin W Exchange, for its drylin W linear system in which the liner can be replaced directly on the...Read More
Portescap Ultra EC Motors Offer High Torque in Compact Package June 26, 2018 Portescap will be offering 2 more new length sizes under its ECT range of Ultra EC Brushless Slotless motors: the 35 mm 22ECT35 and the...Read More
Rexnord Announces Dry-PT Material Option for Select Chains June 25, 2018 Rexnord is proud to announce the latest addition to our premium line of conveying solutions products; the Dry-PT material option is now...Read More
Sakor Supplies Belt Noise Testing for Ford Motor Company June 22, 2018 Sakor Technologies Inc. has supplied an accelerated belt aging stand to Ford Motor Company for use in belt noise testing. The new preli...Read More
Kluber Lubrication Offers Fully-Synthetic Oil for Rail Gearboxes June 21, 2018 Klüber Lubrication, a worldwide manufacturer of specialty lubricants, offers Klübersynth GE 4 80 W 140, a fully synthetic hig...Read More
Joral Announces Stainless Steel Housings for Sensors and Encoders June 20, 2018 Joral LLC announces new stainless steel housings for all currently available sensors and encoders. Specifically designed to ensure tota...Read More
