Mitsubishi Electric Automation, Inc. is proud to be in attendance at the AHR Expo 2024! Mitsubishi Electric has been demonstrating at AHR for almost two decades as one of the leaders in the HVAC industry. The AHR Expo this year will be held at the McCormick Place in Chicago, IL to showcase the industry’s newest technologies and innovations.
A growing number of companies are adopting robotic solutions in their logistics processes. They provide far greater flexibility than conventional automated handling systems, and can seriously boost productivity, throughput and operational accuracy, even in ‘steady state’ operations. Pallet and bin shuttle systems for automated storage and retrieval are a prime example. With modular design, acting as a set of building blocks to minimize complexity and cost of upgrading, these systems are highly scalable installations can start small and then expand or, if needed, they can downsize just as easily.
The AY110-40-01 Rotary Stage (pictured) from Optimal Engineering Systems, Inc. (OES) offers the users a high precision, low profile, compact motorized rotary stage.
Electromate Inc. has announced the pre-order availability of Universal Robots' latest innovation - the UR30 collaborative robot (cobot). The UR30, boasting a 30 kg payload capacity, is the newest addition to Universal Robots' cutting-edge cobot lineup.
With the CP150 compact controller, the wait for the electronics to start up again after the engine is shut down for a short time is completely eliminated. This saves time and increases productivity in everyday work. Operators can eliminate the wait and also decrease emissions with the CP150, reducing their environmental footprint. B&R uses the vehicle's battery for the standby function.
Igus has developed a finger gripper for the ReBeL cobot. The ReBeL can now perform a variety of simple humanoid tasks with the new low-cost robotic hand.
Shaft collars and mounts that can be adjusted without tools, plus handles
and thumb screws to convert standard shaft collars to quick-adjust types,
have been introduced by Stafford Manufacturing Corp. of Wilmington, MA.
Stafford Quick-Adjust Products feature the Flip-Lok with a split hub and
an integral adjustable clamp, Staff-Lok Lever-Actuated shaft collar, and
the Python Flange Mounting Collar with a 6-hole bolt pattern and keyway.
Suitable for a wide range of linear and low RPM rotary applications, these
quick-adjust products can be easily repositioned by hand without tools.
Ruland has released mountable shaft collars with face holes for applications where the shaft collar needs to be directly mounted to a component such as a pulley, sprocket, or metallic plate. The shaft collars are available with drilled face holes that give the user flexibility in mounting hardware, or tapped holes that match the standard screw threading of the collar for ease of installation.
Portescap introduces the 60ECF brushless DC slotted flat motor, the newest frame size to join its flat motor portfolio and a significant expansion of its brushless flat technology capabilities. This 60mm BLDC motor features a 38.2mm body length and an outer rotor slotted configuration with an open body design, allowing it to deliver improved heat management in a compact package.
