Product News June 1, 2009 The complete product news section from the June 2009 issue of Power Transmission Engineering.Read More
Ball Bearing Mini Clutches from Ogura May 28, 2009 Ogura has modified the MC electromagnetic clutch line to incorporate ball bearings. Previous designs had bushings that had limitations o...Read More
Heavy-Duty Slide 2 Improved, Carries Heavy-Cantilevered Loads with Ease May 15, 2009 Techno, Inc. Linear Motion Systems introduces the improved Heavy-Duty Slide 2, constructed from a single rigid aluminum extrusion profile...Read More
Linear/Rotary Platform Combines Material Handling with Direct Drive, Rotary Motion April 23, 2009 The LaserTurn 1 is a linear/rotary motion subsystem that integrates automated material handling with direct drive linear and rotary motor...Read More
Leveling Mounts Feature Rubber Foot that Adjusts to Uneven Surfaces April 14, 2009 A series of metric leveling mounts from All Metric Small Components (aMsp) swivels 15 degrees to all sides of the centerline to adju...Read More
High Speed Ogura Mico Clutch Enhanced to Include Shaft April 13, 2009 Ogura has enhanced the Hi-Mic5 clutch to include a shaft designed to customer specifications. The electromagnetic clutch incorporates...Read More
Ultra Compact 180 W Intelligent Drive with CANopen Mounts Beside Motor April 6, 2009 Technosoft announces the new IBL3605, a compact intelligent servo drive measuring 65 x 58 x 19 mm, which reaches up to 600 W peak power. ...Read More
Dodge Steel-Housed Bearing Installs, Removes Quickly April 3, 2009 The Dodge Imperial HD mounted roller bearing from Baldor Electric Company features a cast-steel housing and is designed for heavy-duty ap...Read More
Grip and Rotate Modules Perform Two Operations in One Compact Package April 2, 2009 Techno-Sommer Automatic has announced the DGP404 series parallel grip and rotate modules with T-slot guides. They are designed for high-l...Read More
Product News April 1, 2009 The complete Product News section from the April 2009 issue of Power Transmission Engineering magazine.Read More
