Machinable Nylon Grade Broadens Size Range October 8, 2009 Nylatron NSM, a wear-resistant machinable nylon grade, is available in a wider range of tubular shapes for machining larger bearings, bus...Read More
Bison Gear Adds 46 Models to FlexTorq Line October 6, 2009 The FlexTorq line of gearmotors from Bison Gear and Engineering Corp. continues to grow with 46 models of the 562 Series of hollow shaft ...Read More
Plug-in Mini-drive with CANopen Interface Runs Complex Motion without External Controller October 2, 2009 PIM3605 extends Technosoft's plug-in mini-drive series by increasing the power capabilities offered by PIM2401 (25 W) and PIM2403 (75...Read More
High Speed, Low Cost Reversing Drive October 2, 2009 Used for double sided copy machines and for other quick reversing industrial applications, the Ogura reversing drive is a cost effective ...Read More
Electric Clutches for Gas and Diesel Engines October 2, 2009 Ogura electromagnetic clutches can handle the torque and speed requirements of most small to midsize gas and diesel engines up to around ...Read More
Product News October 1, 2009 The complete Product News section from the October 2009 issue of Power Transmission Engineering.Read More
User-Friendly Non-Contact Torque Sensor Mounts in Moments September 30, 2009 Sensor Technology Inc.'s RWT 350/360 TorqSense is a non-contact digital torque measuring system that features an integral sprocket or...Read More
Electromagnetic Jack Shaft Clutch September 20, 2009 The model AMC10 from Ogura Industrial Corp. is an electromagnetic clutch that has been developed for an end of shaft connection. The clu...Read More
Excel Gear Designs, Prototypes Navy Gun System Gearboxes September 10, 2009 Roscoe, IL-based Excel Gear has transitioned from prototype to production of 38:1 ratio gearboxes designed for positioning the gun mount ...Read More
PCB Conformal Coating Features Fast Tack-Free Cure September 10, 2009 Moisture-curing silicone conformal coatings are suited as protective coatings for sensitive board components in demanding environments, b...Read More
