AutomationDirect Adds Helical Gearboxes to IronHorse Line June 21, 2016 AutomationDirect’s IronHorse line of motor products now includes helical gearboxes which provide quiet startup and smooth operation...Read More
Cortec Dunnage Bags Offer Shipping Protection June 20, 2016 The corrosion protection power of Nano VpCI is now available in the form of a dunnage bag. Cor-Pak Dunnage Bags powered by Nano VpCI, (pa...Read More
Lenze g500 Servo Adaptor is Compact and Economical June 17, 2016 Lenze Americas recently released a servo adaptor for its g500 gearbox series. The compact design of the new Lenze servo adaptor provides ...Read More
OES Introduces Three-Axis Gimbal Mount June 16, 2016 The high precision, AU300-XZ motorized three-axis gimbal mount from Optimal Engineering Systems, Inc. (OES) features full 360 degrees rot...Read More
Portescap Expands Athlonix DC Motor Series June 15, 2016 Portescap introduces the next frame size in the DCP range of Athlonix high power density brush DC mini motors. Athlonix DCP motors offer ...Read More
SKF Develops Online Heater Selection Tool for Bearings June 14, 2016 The new SKF online heater selection tool introduces an easy, convenient and highly accessible resource to make the right pick among heate...Read More
Cortec CorrLube CpCl Lithium EP Grease Provides Corrosion Resistance for Electrical Connections June 13, 2016 When it comes time to lubricate bearings, fans, chassis or other metal areas where grease is applied, Cortec's CorrLube VpCI Lithium ...Read More
Stafford Rotary Encoder Collars Track Shaft Speeds June 9, 2016 A line of rotary encoder shaft collars that provide targets to let variable reluctance sensors track the speed of rotating shafts or axle...Read More
Ringfeder Smart-Lock Delivers Torque from 580 to 5,600 Nm June 8, 2016 Ringfeder Power Transmission recently announced its new RfN 4001 Smart-Lock set, a flexible, economical hollow shaft connection for inter...Read More
Sprint Electric Presents Range of Digital DC Drives June 7, 2016 Sprint Electric presents its extended range of digital DC drives up to 2,250 amps. The drives of the PLX range are ideal for controlling ...Read More
