MINExpo Preview: Stiebel-Getriebebau GmbH August 5, 2016 Stiebel-Getriebebau has developed advanced pump drives which combine an improved energy balance, greater flexibility and performance. Vis...Read More
Alliance Sensors Introduces LR-27 Series August 4, 2016 Alliance Sensors Group, a division of H.G. Schaevitz LLC., has expanded its sensor product offering by adding to its line the LR-27 Serie...Read More
IMTS Preview: Steinmeyer August 3, 2016 Steinmeyer, a manufacturer of precision ground ball screws, announces its participation in the 2016 International Manufacturing Technolog...Read More
Suhner Offers Standard and Custom Flexible Shafts August 2, 2016 Suhner Manufacturing, Inc. (Rome, Georgia) recently announced the availability of standard and custom flexible shafts for rotary power tr...Read More
Twiflex Expands Modular Brake System with VSD Series August 1, 2016 Twiflex has expanded its modular brake systems with the new VSD Series, which incorporates several of Twiflex’s newest technologica...Read More
Metallized Carbon Corp. Offers Carbon-Graphite Materials for Aircraft Shaft Seals July 29, 2016 Metallized Carbon Corporation offers a variety of materials for mechanical seals in aircraft shaft applications, including main shaf...Read More
SEPAC Designs Thin Spring-Engaged Brake July 28, 2016 SEPAC designed the Thin Spring-Engaged Brake (TSEB) to provide OEMs with a thin body high-performance/low-cost spring engaged power off b...Read More
Curtiss-Wright Launches High-Pressure Valve Sensor July 27, 2016 Curtiss-Wright’s Industrial division has launched the all-new VPT351 valve-position sensor featuring a measurement range of 0-10 mm...Read More
Cortec EcoShield 386 Water Based Coating Achieves 1,000 Hours of Salt Spray Testing July 26, 2016 Through the Nano VpCI coatings chemistry of Cortec Laboratories, the first water based coating has been created to withstand a minimum 1,...Read More
