HSIs Linear Actuator Available with Connector August 7, 2007 Haydon Switch & Instrument introduced its size 11 hybrid linear actuators, now available with an integrated connector.Offered alone o...Read More
Baldor Introduces New Series Adjustable Speed Control and Motor August 7, 2007 Baldor announced a new series of brushless adjustable speed controls and motors featuring less maintenance, quieter operation, more ...Read More
IMI Sensors Vibration Alarm Modules Provide Alarm and Shutdown Protection for Machinery August 7, 2007 The Series 684 indicator alarm module from IMI Sensors division of PCB Piezotronics provides a solution to machine shutdown protection wh...Read More
J.W. Wincos Linear Actuators Feature Two Separate Threaded Shafts August 6, 2007 J.W. Winco's metric linear actuators have two separate threaded shafts and feature guide tubes of chrome-plated precision steel with ...Read More
Omron STI's Switch Locking Devices Enables Quick Moving of a Safety Interlock Switch to Safe Position August 6, 2007 The SLD series switch locking devices from Omron Scientific Technologies enables personnel to quickly lock a safety interlock switch to a...Read More
Cicoils Custom Shaped Flat Cables Eliminate Problems Caused by Precise Routing August 6, 2007 For space-sensitive electronics, Cicoil features custom shaped flat silicone cables. The custom shaping allows for very precise cable rou...Read More
Automation Directs New Temperature Controllers Offer Dual Output Control August 6, 2007 Automation Direct introduced the new SOLO process/temperature controller line with 22 different models.Available in four standard DIN siz...Read More
Ameridrives Introduces New Disc Coupling August 6, 2007 The ASPI-671 compliant disc coupling line for power transmission applications from Ameridrives Couplings was developed with advanced fini...Read More
Sensor Development's Latest Model Measures Small Reaction Torque Level August 6, 2007 The Model 01165 small flange reaction torque sensor from Sensor Development is designed to measure small reaction torqu levels using flan...Read More
