ServoClass Couplings Add Three Sizes May 10, 2010 Appropriate for precision positioning requirements and high reverse load characteristics of challenging AC and DC servomotor applications...Read More
Motion System Software Simplifies Drive Selection May 5, 2010 The Motioneering 6.1.0 motion system sizing and selection software from Kollmorgen is an OEM design tool that uses a mechanism project co...Read More
Linear Rail Consolidates into One System May 4, 2010 The dual carriage RGS04 motorized linear rail assembly from Haydon Kerk Motion Solutions combines several motion technologies into one in...Read More
Bodine Redesigns W Model Gearheads May 3, 2010 The WX gearhead from Bodine Electric Company is a high-torque gearhead built to provide longer life and higher performance than similar g...Read More
Shaft Collars, Couplings Designed for Solar Installations April 30, 2010 Ruland Manufacturing Co. Inc. offers a selection of shaft collars and couplings specifically designed for harsh environments and use in s...Read More
Low Inertia Couplings Reduce Cycle Time April 30, 2010 Zero-Max's low inertia, lightweight coupling with high rotional stiffness for servo motor applications comes with its aluminum CD mod...Read More
Rotary Encoder Measures Speed without Ball Bearings April 26, 2010 The MNI40 incremental rotary encoder from Pepperl+Fuchs is a magnetic, non-contact encoder with advanced diagnostics for a range of appli...Read More
Haydon Adds Third Actuator Size April 16, 2010 The G4 19000 Series Can-stack Stepper Motor Linear Actuator is the third linear actuator size added to the Haydon line of high output c...Read More
Rotary Encoder Operates at High Speeds April 15, 2010 The MSR 40 is a modular steel tape rotary encoder from RSF Elektronik that measures applications with diameters of six inches (150 mm) to...Read More
One-Piece Belt Drive Permits Sag-Free Stroke Lengths April 12, 2010 The model AZ1040 drive is the latest extension to the Amacoil-Uhing line of timing belt drives used for smooth linear motion in positio...Read More
