Miniature Linear Scale Squeezes Into Tight Spaces July 8, 2010 Numerik Jena's Kit L4 encoder is a minimum configuration of a length-measuring system for applications where installation space is ti...Read More
Damped Type Spring Mounts Mount to Heavy-Duty Applications July 8, 2010 A series of damped type spring mounts from Advanced Antivibration Components (AAC) are designed for use in corrosive environments wit...Read More
Ogura Brakes Rated for Higher Torque July 6, 2010 The Ogura OPB series of magnetic particle brakes features the OPB 120N and OPB 250N, rated at 110 inch-pounds and 220 inch-pounds res...Read More
Mini Accelerometer Reduces Unwanted Mass Loading Effects July 1, 2010 The Endevco model 35A from Meggitt Sensing Systems is an IEPE-type triaxial accelerometer with integral electronics. It is designed for h...Read More
Modulated Hydraulic Pressure Source Controls Brake Torque June 29, 2010 The 520 Series hydraulic apply calliper disc brake for on- and off-highway service braking applications uses a modulated hydraulic pres...Read More
Adjustable Speed Drives Set to Various Speeds June 28, 2010 Adjustable Speed Drives with a micro dial feature available from Zero-Max provide accurate, repeatable speed settings. This allows users ...Read More
High Output Can Stack Stepper Motor Linear Actuators June 25, 2010 With frame sizes of 20, 25 and 35 mm, the Haydon line of high out put can stack linear actuators are built to be compact, durable and pow...Read More
Flexible Wire Duct Resilient to Bending June 24, 2010 The Dinosaur self-adhesive flexible wire duct from Automation Direct is designed for transporting wiring to cabinet doors from control ...Read More
Bearing Units Self-Align June 21, 2010 The ready-to-mount bearing units from NKE consist of a bearing fitted in a cast or pressed housing for material handling systems, such ...Read More
Servo Drives Add Supported Standards June 17, 2010 The e100 drive family from Baldor Electric Company has been reengineered to be compatible with at least three industrial Ethernet stand...Read More
