FANUC to Debut Control Innovations at IMTS August 2, 2010 FANUC CNC America will unveil advanced CNC control innovations at IMTS 2010, Booth #S-8919. These include: new model 30i-B Series C...Read More
Product News August 1, 2010 The complete Product News section from the August 2010 issue of Power Transmission Engineering.Read More
Shaft Locking Bushings Incorporate Double Walled Sleeve July 29, 2010 ETP shaft locking bushings from Zero-Max produce accurate and concentric mounting compared to mechanical shaft locking bushings. The E...Read More
Crouzet Expands BLDC Power Range July 28, 2010 A line of high-performance, geared BLDC motors (pictured) is available with a complete tool kit of selectable gearboxes, controllers, bra...Read More
Extreme Environment Sensors Measure without Contact July 28, 2010 Kaman Precision Products line of high precision sensors and systems provide accurate and precise non-contact position/displacement fe...Read More
Encapsulated Power Supplies Added to Rhino Line July 19, 2010 Automation Direct has extended its Rhino line to include AC/DC switch mode power supplies encapsulated in a compact, low profile housin...Read More
Plastic Shaft Collars Match Processing Requirements July 16, 2010 Custom shaft collars machined from various thermoplastics to match process applications requiring chemical resistance and frequent wash...Read More
Encoder Ready DC Motors Feature Planetary Gearboxes July 15, 2010 Nidal Copal's HG16 series is a RoHS compatible DC motor with planetary gearbox. The 0.63 inch OD (16 mm) DC motor has two axial lengt...Read More
Molded Notch V-Belts Constructed of EPDM July 13, 2010 Gates Corporation is now using Ethylene Propylene Diene Monomer (EPDM) to construct its molded notch V-belt line. EPDM is a high performa...Read More
Universal Voltage Alert Certified for Hazardous Areas July 13, 2010 The UPA-130 series Universal Voltage Alert from Marsh Bellofram Corporation has achieved hazardous area certifications (Class 1, Division...Read More
