Applimotion Offers Custom Direct Drive Motor System June 22, 2011 Applimotion recently introduced a custom direct drive motor system with precision encoders and bearings in unique packages. For year...Read More
AutomationDirect Expands ProSense Line June 21, 2011 AutomationDirect has expanded the ProSense line of pressure sensors and temperature transmitters. IP68/IP69K-rated 5,000 psi pressure tra...Read More
Bison's ServoNOW Designed for Single Axis Applications June 20, 2011 Bison's integrated brushless ServoNOW servo system for single axis applications was designed to meet basic motion needs by limiting p...Read More
Baldor Enhances Same-Day Gearbox Assembly Operations June 17, 2011 Baldor has enhanced its fast turnaround gearbox assembly operation, which now has access to a large extensively-equipped machine shop, to...Read More
Zero-Max Hubs Provide Accurate Mechanical Adjustments June 16, 2011 Zero-Max Phas-Lok adjusting hubs provide a fast and easy method for changing the phase relationship of components in a power transmission...Read More
Stober Partnership Creates Rack and Pinion Drive June 15, 2011 In the past, rack and pinion drives were generally developed from a planetary gear unit with a pinion fitted to the output shaft and the ...Read More
Sevcon Motor Controllers Serve Electric Scooter Industry June 13, 2011 With growing worldwide demand for electric scooters, Vmoto E-max has specified new advanced technology motor controllers from S...Read More
NKE Bearings Offer Versatile Solutions June 10, 2011 Bearing manufacturer NKE recently introduced bearing solutions for industrial gearboxes at this year's Motion, Drive and Automation F...Read More
PI Releases Nanopositioning Catalog June 8, 2011 PI, a manufacturer of nanopositioning stages and precision motion control equipment for bio-medical, semiconductor, imaging and...Read More
Stafford Shaft Balancing Collar Provides Simple Solution June 7, 2011 A new shaft balancing collar that provides a fast and simple way to resolve out-of-balance conditions causing vibration in drive systems ...Read More
