Permanent Magnet Motor Offers Efficiency Gains April 17, 2013 SyMAX IHP (integral horsepower) is a permanent magnet AC motor range whose radial flux design delivers high torque, ultra high efficiency...Read More
Bonfiglioli Introduces BMD Motor Line at Hannover Messe April 16, 2013 The introduction of Bonfiglioli’s new family of motors, the BMD Permanent Magnet AC synchronous motor range integrates itself with ...Read More
Amacoil Expands Linear Drive Nut Line April 5, 2013 Amacoil/Uhing has expanded its line of Model RS rolling ring linear drive nuts with the new RS8 drive. The new unit runs on an 8 mm diame...Read More
Coupler Brake Reduces Inventory and Maintenance Costs April 4, 2013 Force Control Industries, Inc. recently developed a double C-face coupler brake that mounts on the drive end of a standard C-Face motor, ...Read More
Oelheld Introduces Water-Based Lubrication Line April 3, 2013 Oelheld U.S. introduces its water based lubrication line. AquaTec 5001 is a high performance, synthetic metalworking fluid specifically d...Read More
Maxon Introduces Micro Motor and Gearhead April 3, 2013 Maxon Motor introduces the EC4, a 4 mm diameter brushless DC motor and gearhead. The typical issue found with micro drives of this size i...Read More
Crouzet Motor Expands DCmind Series April 2, 2013 Crouzet, a brand of Custom Sensors & Technologies (CST), has introduced the DCmind Brushless direct current motor series, augmenting ...Read More
Product News April 1, 2013 SKF energy-efficient bearings, Bishop Wisecarver guided motion system, Weiss torque rotary table, Mico wireless braking system, Nord worm gear series, and SKF expanded range of couplings.Read More
Huco Examines Flexible Coupling Selection March 28, 2013 Flexible shaft couplings connect two shafts, end to end. They transmit rotation from one to the other and accommodate the slight, unin...Read More
Altra to Exhibit at Coal Prep 2013 March 27, 2013 Altra Industrial Motion brands Marland Clutch and Formsprag Clutch will be exhibiting their latest product lines in booth 1405 at the 201...Read More
