Maxon EC-i 40 Brushless Motors 70% More Efficient Than Precursor Model June 15, 2015 Maxon recently expanded its line of EC-i 40 brushless motors with three iron-core internal rotor drives. The drives have a diameter of 40...Read More
NKE Agri Units Make Agricultural Rolling Bearings Simple June 12, 2015 NKE recently introduced all-in-one bearing units designed for use in agricultural machines that require a rotating union between a disc-s...Read More
Haydon Kerk Supports Security Door Actuation Market with Customized Hybrid Linear Actuators June 11, 2015 Quiet, energy-efficient linear stepper actuators from Haydon Kerk Motion Solutions can serve as replacements for loud and power-hungry so...Read More
LM76 Offers Low-Cost, High-Accuracy, Straight and Curved Rail & Roller Block Systems June 10, 2015 Low cost, SAIBO SB-LGV straight and curved rail and roller block systems are available from LM76 in three widths, and two styles to meet ...Read More
Ruland Oldham Couplings Can Be Used in Print Applications June 5, 2015 Ruland manufactures zero-backlash oldham couplings that accommodate high amounts of parallel misalignment with low bearing loads and have...Read More
QA1 Releases Staked Design and Quick Connect/Disconnect Ball Joints June 4, 2015 QA1 Precision Products, Inc., recently released staked design ball joints and quick connect/disconnect style ball joints for the industri...Read More
Expanded Line of LeCentric Helical In-Line Reducers Includes Ratios up to 18,587 lb-in Torque June 3, 2015 Grove Gear's expanded range of LeCentric helical in-line reducers offers advantages for OEM and MRO applications alike, with quick de...Read More
Regal Introduces Mill-Drive Condition Monitoring Program June 1, 2015 Regal Power Transmission Solutions recently introduced its new mill-drive condition monitoring program at AISTech with technology that mo...Read More
J.W. Winco Now Offers Lifting Eye Bolts in Inch Sizes May 28, 2015 J.W. Winco, Inc. recently announced it now offers WN 580 inch size lifting eye bolts. Eye bolts are made of forged1030 carbon steel, ASTM...Read More
