Minnesota Rubber and Plastics' Design Guide Has Hundreds of Pointers on Designing Custom-Molded Rubber and Plastic Parts August 3, 2015 Minnesota Rubber and Plastics recently released its latest design guide for planning component and assembly designs. Available now in USB...Read More
Siemens Combination Motor/Drive Packages Bundled to Fit Individual End-User's Needs July 31, 2015 Siemens Industry, Inc. recently announced the release of combination motor/drive packages, allowing an OEM or end-user the option to sele...Read More
Stafford Shaft Collars and Couplings Include 3,600 Standard Items for Building and Maintenance Converting Equipment July 30, 2015 Stafford is now offering its standard line of shaft collars and couplings in a range of designs and materials for building and maintainin...Read More
MET High-Current Brush DC Motor Develops 500 Watts Continuous Output Power at 2,000 RPM July 29, 2015 Minnesota Electric Technology (MET) recently developed a family of high-current brush DC motors in 3.6 inch frame size. These high-curre...Read More
Quicksilver Mosolver Sensor Provides 32,000 Counts of Position Information July 28, 2015 QuickSilver Controls, Inc. recently extended their Mosolver (Motor + Resolver) technology into the compact 17 frame format. The Mosolver ...Read More
Pittman Motors EC042B Brushless DC Motor Designed as an Economical, High-Performance General Purpose Servo Motor July 27, 2015 Pittman Motors recently introduced the EC042B brushless DC motor series, its latest DC brushless motor. The high torque density model is...Read More
Exsys to Showcase New Gearbox Solutions at WESTEC July 23, 2015 At WESTEC 2015, Exsys Tool, Inc. will showcase advanced manufacturing technologies in booth 1919. Amongst other products, new gearbox sol...Read More
JVL Hollow Core Rotary Actuators Available With MIS231 Integrated Stepper or Servo Motor July 22, 2015 JVL recently introduced six Hollow Core Rotary Actuators. These integrated rotary actuators are available in two table sizes, the HDCT-10...Read More
Amacoil/Uhin Elasto-Ring Washer Reduce Pressure Between U-Clip and Flange July 21, 2015 Amacoil/Uhing recently introduced the Elasto-Ring washer for use with U-Clip quick release shaft collars. Elasto-Ring installs by hand wi...Read More
