Force Control Offers Posidyne Clutch Brake in Piggyback Design February 28, 2017 Posidyne clutch brakes, with oil shear technology that allows rapid and precise stopping, starting, reversing, speed change and positioni...Read More
Miki Pulley Micro Clutches Designed for Compact Precision Applications February 27, 2017 Miki Pulley is introducing its CYT Micro Clutches for direct sale to OEM’s in North America. These CYT Clutches are designed for co...Read More
R+W Safety Couplings Suitable for Wastewater Applications February 24, 2017 By popular demand, R+W has developed a standard model of corrosion proof ball detent safety coupling for clarifier drives in water treatm...Read More
Stafford Expands Shaft Collars and Couplings for Mechanical Drive Systems February 23, 2017 An expanded line of metric shaft collars, couplings, and mounting components suited for mechanical drive systems and structural applicati...Read More
Iwis Drive Systems Introduces Maintenance-Free Chains February 22, 2017 Iwis drive systems introduces b.dry maintenance-free stainless-steel chains. The corrosion-free chains run completely dry, are extremely ...Read More
Zero-Max ETP-EXPAND Improves Pump Drive Connection February 21, 2017 Connecting a rotating piston lobe to a hollow shaft has been improved using the ETP-EXPAND, a patented bushing device that is fast and ea...Read More
ACS Develops CNC HMI Platform February 16, 2017 ACS Motion Control has developed a customizable CNC HMI Platform for high precision machining and processing applications. Designed with ...Read More
SG Transmission Designs Curved Permanent Magnet Brake February 16, 2017 SG Transmission has designed a curved permanent magnet brake to be used in specialist medical equipment. The customized brake has be...Read More
Moticont Adds Two Linear Motors to SDLM Series February 14, 2017 Moticont has added two linear motors to its SDLM series of high speed direct drive linear motors which are also known as electric cylinde...Read More
HBM Inc. Offers Digital Torque Transducer February 13, 2017 HBM, Inc. has introduced the new T12HP digital torque transducer. The T12HP supports dynamic measurements in the test stand and provides ...Read More
