JW Winco Expands Line of Nylon Plastic Wing Nuts May 8, 2019 JW Winco, Inc., A Ganter Company, has expanded its line of GB-FP Wing Nuts Nylon Plastic, with Tapped Through Insert.“The tapped th...Read More
Dunkermotoren BG Series Matches with Simatic Micro-Drive from Siemens May 7, 2019 With the brushless DC motors (24 to 48 volts) of the series BG 45, BG 65(S), BG 75 and BG 95, Dunkermotoren has been the market leader in...Read More
Ruland Offers Stainless Steel Oldham Couplings May 6, 2019 Ruland now makes oldham coupling hubs from 303 stainless steel. This addition gives designers an off-the-shelf coupling to choose from wh...Read More
B&R Offers Controller and Multi-Touch HMI in One Device May 3, 2019 B&R's new Power Panel C50 provides the combined advantages of a powerful controller and a modern projected capacitive touch scree...Read More
Atlanta Drive Systems Offers Range of Stainless Steel Washdown Gearboxes May 2, 2019 Atlanta Drive Systems, Inc. is pleased to announce a new range of stainless steel washdown gearboxes, perfect for use in demanding appl...Read More
FVA-Workbench 5.5 Offers Detailed Transmission Calculation Results May 1, 2019 FVA-Workbench Version 5.5 of the simulation platform for transmission systems, released in May, accelerates development processes and pro...Read More
Haydon Kerk Pittman Introduces New HKP Mobile App April 30, 2019 Haydon Kerk Pittman, a business unit of Ametek Advanced Motion Solutions division, recently announced the release of the HKP Mobile App...Read More
H2W Technologies Examines Coil Redundancy April 29, 2019 In the case where an actuator is installed in a location where access is limited or where downtimes may be costly, there is a need for re...Read More
Stafford Announces Drone Fixed and Adjustable Attachment Options April 26, 2019 A wide range of standard and special shaft collars, couplings, and quick-change mounts for use with commercial and military drones are ...Read More
Marland Monitoring System Provides Remote Access to Backstop Operating Conditions April 25, 2019 Marland Clutch recently introduced the Smart Marland Monitoring System that provides up to the minute access to critical backstop opera...Read More
