Bishop Wisecarvers Newest Linear Actuator Completes Product Line April 14, 2006 Bishop-Wisecarver Corp.s new SRX-150 is a high precision, compact aluminum profile linear actuator thats available in belt or...Read More
Avtron Manufacturing Announces Magnetic Encoder April 14, 2006 Avtron Manufacturing, a manufacturer of industrial motor speed control equipment announced the first shipments of its new HS35M magnetic ...Read More
Tornos Technologies Debuts New Swiss-Type Multi-Axis Machine April 14, 2006 The new DECO 8sp single-spindle Swiss-type multi-axis, multi-function machine will be making its debut at IMTS. The machine accommoda...Read More
Steinmeyers New Rotary Stage Features Built-In Stepper Motor and Controller April 14, 2006 Steinmeyer, Inc. announced a new precision rotary positioning stage. The fully integrated and compact DT 200-SM "plug and play" rotary st...Read More
HSIs Linear Actuators Include Encoder Feedback April 13, 2006 Haydon Switch & Instruments size 11 hybrid linear actuators are now available with encoder feedback. According to the company&...Read More
Zero Maxs New Linear Actuators Convert Rotary Motion into Precise Linear Motion April 12, 2006 The Rohlix linear actuators from Zero-Max convert rotary motion to linear travel and carry loads at speeds up to 70" per second, de...Read More
Bison Gear Introduces Line of AC Motors April 12, 2006 Bison Gear & Engineering introduced a new line of custom AC motors manufactured in their St. Charles, IL, facility. Motors will be ava...Read More
Samputensili Master Gears Personalized to Customer or DIN Specifications April 12, 2006 Samputensili has introduced a range of master gears to determine work gear accuracy and setting masters to adjust checking equipment. ...Read More
Weilers New Brochure Details In-Machine CNC Deburring on Flat Surfaces April 11, 2006 Weiler Corp.s newest brochure details its in-machine CNC deburring of flat surfaces and highlights the companys Nylox disc br...Read More
SKFs New Cylindrical Roller Bearings Extend Wind Turbine Gearbox Life April 11, 2006 New SKF high-capacity cylindrical roller bearings for wind turbine gearboxes have been engineered to promote longer gearbox service life...Read More
