Lin Engineering Releases Step Motor, Driver, Controller and Encoder in One Unit March 8, 2007 Lin Engineering released the SilverPak 23CE, an integrated NEMA 23 high torque step motor, microstepping driver, intelligent controller,...Read More
Leroy-Somer Designs Geared Motor for the Food Industry March 8, 2007 The new Multibloc IAW FLS IAW worm geared motor range from Leroy Somer was designed for extreme use conditions and harsh environments suc...Read More
PCB Piezotronics Publishes New Sensors Catalog March 8, 2007 PCB Piezotronics, Inc. announced the release of a 200-page product catalog, entitled, "Sensors for Force, Load, Strain and Torque." ...Read More
Philadelphia Gear Offers Two Versions of Continuous Oil Rescue Equipment March 5, 2007 Philadelphia Gear Corp. announced the availability of two versions of the company's proprietary CORE Continuous Oil Rescue Equipment....Read More
New Parallel Shaft Gearmotors from Sharq Motion Offer Backward Compatibility March 5, 2007 The new Sharq 207 series parallel shaft gearmotors, designed as direct drop-in replacements for many high volume OEM applications are the...Read More
Sicks New Sensor Offers Micro-Level Performance March 2, 2007 The new OD Max displacement sensor from Sick Ltd. is suitable for applications where distance measurement is required with an accuracy i...Read More
Leroy Somers Powerdrive Requires Only Eight Parameters for Application Commissioning March 2, 2007 The Powerdrive from Leroy Somer covers the range from 45 to 675KW, and is modular with air or liquid cooling and offer open- or closed-lo...Read More
High Performance Stepper Drives with Advanced Features and Control Options Available in 200VAC Models March 2, 2007 Applied Motion Products family of STAC6 High Performance Stepper Drives are now available in 220 VAC models. According to the c...Read More
Tsubackis Linipower Jacks Lift and Actuate March 2, 2007 Tsubaki UK launched a new range of high precision power jacks for lifting and actuation tasks. The comprehensive Linipower range, with th...Read More
Leroy Somers Newest Motor Takes Extends Varmecas Range to 11kW March 2, 2007 Leroy-Somers Varmeca 30 motor with integral variable-speed drive has extended the Varmeca range up to 11kW. Now available from ...Read More
