Schurter Offers Metal Switch with Double Pole Contacts and Sealed Microswitch November 19, 2007 Schurter Electronic Components has expanded their vandal-proof metal switch to include double pole and sealed microswitch versions. The M...Read More
SKF Polymer-Type Bearings Improve Performance November 16, 2007 The new SKF polymer cages offer advanced thermal, friction and wear properties compared with conventional steel, polymer or brass counter...Read More
Torque/Thrust Sensors Boast Multiple Components November 16, 2007 Sensor Development Inc. recently introduced sensors designed to simultaneously measure both torsion and thrust loads used in test systems...Read More
Lenze Expands Range of Geared Servo Motors November 15, 2007 The MC range of Lenze motors has recently expanded to cover more than 7,500 selections with in-line or right-angle gearboxes. According t...Read More
Baldor Adds High-Powered, Ethernet-Compatible Motor Drives to Lineup November 15, 2007 Baldor recently added three higher power AC motor drives to its product line. The Motiflex e100 drives are Ethernet-compatible with Power...Read More
Bridge Connections Provide Solution for Running Parallel Systems November 14, 2007 The Bishop-Wisecarver Corp. recently announced the addition of bridge connections to its UtiliTrak product line. Available in steel and a...Read More
RENCO Introduces Low-Cost Optical Encoder November 14, 2007 Renco Encoders Inc. recently introduced a low-cost optical encoder that provides more than eight different connector configurations. Acco...Read More
PI Unveils Compact Linear Motor Actuator November 14, 2007 PI (Physik Instrumente), a manufacturer of nanopositioning and piezo-based motion control equipment, recently introduced the N-310 NEXACT...Read More
Rino Mechanical Components Inc. Launches E-Series Gearboxes November 14, 2007 With a recent upgrade to its mechanical tools, Rino Mechanical Components Inc. unveiled its new E-series of gearboxes. The E-series featu...Read More
LMC Workholding Introduces Neidlein Face Driver November 2, 2007 LMC Workholding recently unveiled its Neidlein FBS MK5 model face driver, designed specifically for hard tuning or grinding operations. T...Read More
