Pack Expo Las Vegas (Sept. 23-25; Las Vegas Convention Center), co-located with Healthcare Packaging EXPO, showcases the latest packaging technologies to help manufacturers improve operations and stay competitive.
Downtime, downtime, downtime. When it's
planned, it's bearable. When it's not, it's not. To maintain machinery, planned downtime is necessary.
To fix broken equipment, unplanned downtime is excruciating,
especially when your factory is running closer and closer
to full capacity.
In a research project at the Vienna University of Technology, the KISSsoft design software was used to check a new drivetrain concept and the micro-geometry of the bevel gear stage for a UAV (unmanned aerial vehicle).
Modern aircraft, missiles and space vehicles employ a large number of electric motors and actuators. While the basic design of these motors is in many respects very similar to that of their automotive and industrial counterparts, motors for aerospace applications differ significantly in some areas.
Chain and sprocket drives of one form or another have been driving machines and
conveying materials for over a thousand years. The chain manufacturing industry has developed numerous types and sizes of drive chains. Although it is a mature form of power transmission, there are still many industrial applications for which drive chain is suited. It is economical, resistant to shock loads, easy to install, has the ability to transmit high torque, operates in hostile environments, and is efficient. Chain and sprocket drives are highly engineered and manufactured within close tolerances.
Navigating Clutch/Brake Operation
in Harsh Environmental Conditions: Chemicals, saltwater, food particles, heat, dust, and electrical corrosion are just a few of the many issues that can
cause clutches and brakes to fail prematurely.
