Does the definition of specific sliding mean the same between ISO 21771:2007 and AGMA 917-B97? In ISO, specific sliding is the ratio of the sliding speed to the speed of a transverse profile in the direction of the tangent to the profile. In AGMA, specific sliding is ratio of gear tooth sliding velocity to its rolling velocity.
I'm not able to get a good connection
between the pulley and shaft in my drive
assembly. Could you explain the various
ways of connecting a pulley to a shaft to
prevent the pulley from slipping?
Referencing a June 2014 Article, “High Gear Ratio
Epicyclic Drives Analysis,” by Dr. Alex Kapelevich:
I have designed a small compound epicyclic gearbox
with common planets.
Sun = 10 teeth
Planet = 14 teeth
Ring Gear stationary = 38 teeth
Ring gear output = 41 teeth profile shifted onto a 38
tooth pitch diameter.
Carriers are simply cages for the planet alignment
and location.
According to your article, and according to my
calculations and the prototype I have built, my inputto-
output ratio is a reduction of 65.6:1. I am using a ~
VG1 viscosity grease and Nylatron materials for the
gears and carriers.
