A worm drive is a geared power transmission device in which a worm meshes with a worm gear to transmit power between two non-intersecting shafts that are oriented at a right angle. The worm drive has been an active and challenging topic of technological study since Leonardo da Vinci (1452-1519).
Beginning with a brief summary and update of the latest advances in the calculation methods for worm gears, the author then presents the detailed approach to worm gear geometry found in the revised ISO TR 10828. With that information, and by presenting examples, these new methods are explained, as are their possibilities for addressing the geometrical particularities of worm gears and their impact upon the behavior and load capacity of a gearset under working conditions based on ISO TR 14521 — Methods B and C. The author also highlights the new possibilities offered on that basis for the further evolution of load capacity calculation of a worm gearset based on load and contact pressure distribution.
Today, better fuel economy is a main objective in the automotive development process. It remains top-of-mind with the auto industry and consumers because of costs and environmental impacts. Because the industry’s average fuel-economy standard is required to increase by 40 percent by 2020, manufacturers and engineers are working to develop fuel-efficient, environmentally friendly and reliable designs for vehicles.
