Regal Rexnord Corporation has added two new models to its portfolio of Boston Gear Gen2 SS700 Series stainless steel worm gearboxes. The new sizes bring the full product lineup to seven. A larger output shaft bore expands the number of applications each model of gearbox can support, providing flexibility and versatility for customers in a range of industries, including food, beverage and pharmaceuticals.
Boston Gear recently introduced the next generation of its 700 Series Worm Gear Speed Reducer. The SS700 Gen2 stainless steel speed reducer is an evolution of its first-generation series that has served the food and beverage industry for over 10 years.
The cylindrical die rolling process can produce helical, axial, and annular forms on shaft-like parts at high rates of speed with precision tolerances.
Why use the rolling process to produce high accuracy lead screws, actuator screws, and other power transmission components rather than traditional cutting processes such as turning, grinding, milling, whirling, or hobbing? Rolling processes and cutting processes both produce a precise form on the workpiece. But if the form geometry, tolerances, and material selection allow, rolling is the process to beat. Speed, surface finish, fatigue strength, precision, dimensional stability, and material savings are some of the primary advantages realized when the rolling process is applied.
Find out about the benefits of a high performance Servo Worm Gearbox, and get an understanding of what applications & industries are ideal for this gearbox. By watching this webinar you will be able to identify applications well-suited for a high performance servo worm reducer and understand the construction differences among each model of DieQua's servo worm gear reducer.
A worm drive is a geared power transmission device in which a worm meshes with a worm gear to transmit power between two non-intersecting shafts that are oriented at a right angle. The worm drive has been an active and challenging topic of technological study since Leonardo da Vinci (1452-1519).
