A new line of belts and accessories for industrial and automotive markets
October 5, 2022
JKF Americas Inc, a subsidiary of JK Fenner (India) Ltd., has introduced their extensive Top Drive line of power transmission products to the North, Central and South American markets. The launch of the Top Drive brand is especially timely for businesses that have seen delays and shortages in the supply chain, within the context of the emerging sourcing model across the world.
Synchronous drives are especially well-suited for low-speed, high-torque applications. Their positive driving nature prevents potential slippage associated with V-belt drives, and even allows significantly greater torque carrying capability. Small pitch synchronous drives operating at speeds of 50 ft/min (0.25 m/s) or less are considered to be low-speed. Care should be taken in the drive selection process as stall and peak torques can sometimes be very high. While intermittent peak torques can often be carried by synchronous drives without special considerations, high cyclic peak torque loading should be carefully reviewed.
If you’re replacing your belts more than once per year, it’s time to analyze your drive. From belt crimping damage to high belt installation tension to sprocket misalignment and adverse environmental conditions, this guide walks you through how to identify the reasons behind premature failure and makes recommendations on corrective and preventive measures.
