Optimal Engineering Systems, Inc. (OES) has added four high-resolution, low-profile goniometers to their expanding catalog of high precision positioning stages. This newly released, AK120-45 Goniometer Series features precision ground worm gears with a 296:1 ratio and pre-loaded cross roller guides, and +/- 45 degrees of travel with 10 kg of load. The very high resolution of 0.0006 degrees (2.16 Arcsec.) is realized when using the standard Two-Phase Stepper Motor driven by a 10 micro-steps per step micro-stepping driver or with the servomotor options and Quadrature Optical Encoders.
OES (Optimal Engineering Systems, Inc.) has added vertical stages to their extensive line of high accuracy, high resolution lift stages. The Z110 Series of Z-axis Stages are available in travel strokes of 15 mm (0.590 in.), 30 mm (1.181 in.), 50 mm (1.969 in.), and 75 mm (2.953 in). These black anodized aluminum alloy stages feature preloaded crossed roller bearings and 1 mm per motor turn lead screws.
Zero-Max has added to their field-proven ServoClass Flexible Shaft Coupling line with the introduction of the new ServoClass-HSN Coupling to address noise and vibration issues that can be experienced in certain high gain, high speed stepper/servomotor applications.
New High Precision Dual-axis ZVR-60-60 Series of Lift and Pitch Stages have been released by Optimal Engineering Systems, Inc. (OES). These compact stages feature 60 mm +/- 2 mm (2.362 in. +/- 0.078 in.) of vertical travel and a vertically mounted rotary stage. The scissor lift design combined with precision roller bearings and slide rails assures smooth motion and very high parallelism throughout the raising and lowering of the table. The Rotary Stage is capable of continuous 360 degrees CW or CCW rotation.
Measure angles or move to a precise angular position with a new series of high precision, low cost XYHG Multi-axis Stages that can be easily integrated into new and existing applications from OES (Optimal Engineering Systems).
The ATR-V-60-60 Series (-01 thru -04) of Dual-axis Elevator-Rotary Stages has been released by Optimal Engineering Systems, Inc. (OES). These compact, Elevator-Rotary Stages feature a high stability Elevator Stage with 120 mm x 80 mm table and 60 mm +/- 2 mm of vertical travel and a load capacity of 5.0 kg. A 60 mm diameter Rotary Stages is mounted vertically. The scissor lift design of the elevator stages combined with precision roller bearings and slide rails assures smooth motion and very high parallelism throughout the travel of the table. The rotary stages capable of continuous rotation feature high precision bearings and 90:1 worm gear.
Intellidrives new overhead XY gantry built with precision ball screw actuators and are offered in travel length from 100 to 600 mm. They can be motorized with stepper motors, brushless servomotor/encoders or integrated Smart motors.
