GWJ Technology GmbH has presented a new version of its desktop solution TBK with numerous enhancements, particularly in the field of gearing. The TBK calculation software has been used successfully worldwide for more than four decades to dimension gears, shafts, connections, bearings, and other machine elements as well as complete gearboxes. With its various interfaces to 3D CAD systems, the TBK software is a powerful calculation tool for development, design, work planning, production, and quality assurance.
Localized production of all-in-one precision line shaft couplings is on the rise, making simpler and more elegant mechanical linkages easier to obtain and more realistic to use – impacting how larger platform motion systems are designed.
Ruland Manufacturing now offers rigid couplings with inch-to-metric bores as a standard product, giving users a wider range of off-the-shelf couplings. This expansion is the latest addition to the company's inch-to-metric, standard coupling product line that includes seven types of motion-control couplings and universal joints. Instead of re-machining or ordering custom-made couplings, using off-the-shelf, inch-to-metric rigid couplings saves time and money.
KISSsoft training courses cover various categories - basic, advanced, special - and take place either via Live Stream or at the KISSsoft AG premises in Switzerland. Based always on the current KISSsoft release, they give you the possibility to enhance and deepen your software knowledge and skills with regards to KISSsoft modules and functionalities.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 31 countries on 4 continents. The new version is now available.
KISSsoft has announced that NSK has provided their extensive bearing data “catalogue data” for inclusion in KISSsoft software with release 2023. With this, the engineer can execute static rating, basic and modified life rating based on load capacity numbers in line with ISO 281 and ISO 76 along with thermal rating. The bearing database in KISSsoft gives access to up-to-date NSK bearing data in an easy to use yet detailed manner using the shaft-bearing system modeler.
When selecting couplings for precise motion applications there are often questions about the most suitable approach for optimizing both performance and economy.
April 6, 2023
